slow WiFi on square M8
Hi All, We have an M8N and an M8 (k200 model) and the WiFi on them appears to be slow (5-10mbit max on a 25mbit connection). The problem doesn't seem to be with my router as I get close to the full 25mbit on a laptop. Thought it might be a firmware problem so I flashed the M8 with the latest radioman mbox rom V5 and still had the same problem. Could this be a hardware issue (the 2 boxes were from 2 different places). All speed tests were done using the oogla speedtest.net app.Tags: None
Originally posted by thekider View PostHi All, We have an M8N and an M8 (k200 model) and the WiFi on them appears to be slow (5-10mbit max on a 25mbit connection). The problem doesn't seem to be with my router as I get close to the full 25mbit on a laptop. Thought it might be a firmware problem so I flashed the M8 with the latest radioman mbox rom V5 and still had the same problem. Could this be a hardware issue (the 2 boxes were from 2 different places). All speed tests were done using the oogla speedtest.net app.
few people have reported slow wifi on the firmware mentionedBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postfew people have reported slow wifi on the firmware mentioned
If it's not a hardware issue then I can try other firmwares, was thinking of trying out finless latest or your 1.6 (couldn't find info on this wake me scottie app so, I don't want to go for the 1.6b)
Originally posted by thekider View PostThanks for the info. Reading the thread for radiomans rom and didn't see many mentions of wifi being slow.
yes you can try finless I'm sure you would get great results you have a smorgasbord of ROMs to choose from.
what works for 1 person does not work for the other trial and errorBugs are Sons of Glitches!
JustMe
Originally posted by grant2258 View PostI had problems with wifi fitted an external antenna problems gone. The excuse for an antenna in the box is a joke.
Well I just got one of these http://m.****.co.uk/itm/220709111448...=1493189787012 cut the end off and soldered it in. Not too hard if your comfortable with soldering
Been connected to my router directly using enet myself, was trying to figure it out for a friend (M8N is our box, M8 is friend's box). What I've found though, even though the speedtest.net app shows slow speeds on WiFi, when streaming videos over wifi there's no lag or buffering issue (unless the video is streaming from a crappy server).
How much improvement did you see ???
QUOTE=grant2258;n404807]Well I just got one of these http://m.****.co.uk/itm/220709111448...=1493189787012 cut the end off and soldered it in. Not too hard if your comfortable with soldering[/QUOTE]
There are currently 2949 users online. 0 members and 2949 guests.
