What is the micro SD maximum that can be put to the CUBE TALK 9X ???
    Hi, I wanted to know which is the maximum size of SD card, that I can get to the Cube Talk 9x ...
    Micro SD 64 GB ???
    Micro SD 128 GB ?
    Micro SD 256 GB ???
    What micro SD you have you? ... Thank you very much ¡¡
    Micro SD 64 GB ???
    Micro SD 128 GB ???
    Micro SD 256 GB ???
    max 32GB.
      Strange...I've 64gb card...
        SDXC support
        Originally posted by dowista View Post
        max 32GB.
        Not true!
        Cube Talk 9X has SDXC support. That means you can use atleast 64Gb (and maybe even 128Gb) sd-cards with standard format (exFAT). However, if you use non-standard format (for example ext4) you can easily use 128Gb. I guess that you can even use FAT32 format with 128Gb sd-card but then the maxium size of one file is 4Gb.
          In theory, being capable of sdXC, the maximum capacity suitable for our cube should be 2TB...
          But at the moment none of us have tested a micoSD greater than 64Gb.
            There is also another thead about this sd-card thing.
            Originally posted by gwenhael View Post
            For the record I have a 128GB Sandisk card in mine (900supersport ROM 20140903) and it's working just fine. I may have had to reformat it as vfat but that's all.
              There seems to be a person who says it has MICRO SD 128 GB ...
                Not true!
                Up to now, I was not able to use exFAT at all. With a modified load (lepi 2.04), it was possible to use 64GB microsd with ntfs, though not tested much up to now.
                By the way: SDXC has different flavours. UHS-1 (which is hardwarely same as SDHC) works.
                UHS-2 etc. are not supported.
                  Well, that is strange because there are people who have reported that 64Gb cards are working great! Devicespecifications.com says also that SDXC is supported. That means exFat should be supported.
                    Devicespecifications.com is not a reliable site, it says also that:
                    - Operating system of talk 9x was 4.2.2 (NEVER released for talk 9x)
                    - Frequency is 2GHz (it's 1.67GHz)
                    - compass (NOT present on talk9x and T9 too)
                    - Video resolution 1080p (if I remember well is only 720p)
                    so I suppose that the only way to know the thruth is a test!
                      128GB Micro-SD is possible
                      Hi all !
                      Tested and proofed ! 128GB Micro-SD is working fine in my U65GT.
                      Greetings from germany
                      Dirk
                        fantastic!
                        Which file system did you use to format it? (ntfs, exFat, fat32).
                        Are you able to write on it from the tablet?
                        Which ROM are you using for U65GT?
                          Originally posted by giouncino View Post
                          fantastic!
                          Hi all !
                          I use the Lepi 2.0.4 Firmware. I dont know which filesystem it is but after inserting the card to the tablet i used the Format Option or prepare option from the tablet in the Settings. And after all i use the card as a backup/working space for my pictures/photos. U will have full access to the card.
                          Dirk
                            It's great to know that it works 128 GB card, you've tried to fill the card to see if it works all card ...
                            I'm thinking of buying this card 256 GB, this in on ALIEXPRESS ... Just is not good card or a hoax, what do you think ????
                              Hi all !
                              Here in germany i have NOT seen any micro-sd-card bigger than 128GB. Even at Amazon there is no 256GB Micro-sd.
                              In my opinion it is a fake card.
                              Greetings
                              Dirk
