Cube Talk 9x bluetooth keyboard (where?)
    Where i can buy this bluetooth keyboard for cube talk 9x??? i cant find..
    This china-tel wont talk, russians dont undarstand english...
    It is for iPad Air
    That keyboard is for iPad Air! Since Cube Talk 9X (237x170x7.5mm) is very similar to iPad Air (240x169.5x7.5mm) the keyboard might be compatible with Talk 9X. Here (link, link, link, link, link) are very similar keyboards than you posted.
    Actually here and here is the same one (black) than you posted.
      but this ipad keyboard can be used with cube talk? thx you for your post.
      Actually here is the same one (black) than you posted.
        I don't know for sure. But since the dimensions are almost the same it might be compatible with Cube Talk 9X too. I think that the thickness is the most important thing. The thickness is same (7.5mm) in both tablets so there is good change that the keyboard and Cube Talk 9X fit together.
          Usb keyboard
          Maybe someone has the same problem that on keyboard some letters donĀ“t work. The solution is to re-mapping the keyboard, description is in this forum. http://www.techknow.me/forum/index.php?topic=5223.0 This solution needs ROOT ACCESS!!! and if you modifying the file all lettes must be CAPITAL LETTERS.
