M8 amlogic box fried?
Hi All, I made a stupid mistake earlier. Both my M8 box and Router which are side by side have the same power lead and I stupidly plugged the router one into my M8. The power lead for that has a higher voltage. My M8 box appears dead as a doornail. Is there any compnent that can be replaced to repair it for this scenario or would I have to buy a new box? -
I wish it was as simple as replacing a fuse but I am sure it isn't. Without equipment and technical expertise, I am afraid a new box is the only answer since if you have the equipment and technical expertise, you wouldn't be asking this question here. Of course take it apart and try to determine which parts are fried before throwing it away, just don't waste any money or a lot of time if you are a busy person.
There are currently 3063 users online. 0 members and 3063 guests.
