Pipo provides you a working hardware, you can't ask them to support support all modifications you might do to your box.
You want to hack your hardware, then you have to deal with that and learn to modify it without breaking it and/or plan for a recovery plan BEFORE you try something that might break it. That's why we need a way of dumping/restoring the BIOS, so that we can experiment with the settings and revert to working condition if something goes wrong.
The other option is that you buy a more finished product with a specific bios (not a generic one that fits many similar tablets / nettop). The manufacturer will have done more work to provide you this, so it'll be twice or three times the price
