MINIX X7mini KitKat 4.4.2 CE ( Community Edition 2.2.0 ) ported to UGOOS UT1
    Hi all ,
    I think this is the best firmware for UGOOS UT1 !!!!
    Try it : Download link
    All credits goes to :
    @gufone
    @KAR
    @HardwareGuru
    WARNING!! WARNING!! WARNING!! NOT EASY TO GO BACK TO 4.2!!
    (You need to use RK flashtool, do not try to flash it like an OTA update.zip !)
    Available Updates:
    Kitkat CE - root update
    Kitkat CE - unroot update
    Later edit : I can`t find a kitkat kernel for UT1 that work fine on network . For some reason works much better for me on wireless then wired network . Thats why on large blue ray movies it`s imposible to play properly over SMB.
    Need help
    Hello, I have a question regarding this firmware, how can I root this?
    Have tried for 2 hours nothing works so please if they are someone who knows I would be grateful.
      It doesn't work for me. Continuously restart at start screen
        Thanks for the heads up on this rom. This rom has given my UGOOS UT1 a whole new lease of life. Everything is working perfectly.
          Pls, can someone upload the ported Rom again? At Mega for example. The downloadlink isnt working :/
          cx-919ii
            Here's a link . https://mega.co.nz/#!FUgFDBZR!JUms97...VCwq99727bMock
              Just a heads up. If you install this rom it will auto get the over the air updates from Minix rom. Currently version 230 community edition. This update disables wifi. You will need to install correct kernal to get wifi working again.(or say no to update when asked) For me Lan connection is better. This gets LAN working again with 230 rom. Nochange to kernal needed.
              http://www.geekbuying.com/item/High-...et-314264.html
                Pls, can someone upload the ported Rom again? Will be much appreciated.
