Thx - JF
Can't boot into recovery after flashing
I purchased (2) OTT TV Boxes marked EM8 (on bottom) M8 on top of box. I just flashed (1) with MBOX_112k4_sdcard.zip (in this thread). Box is working fine with exception of round remote doesn't work; no big deal cause I use wireless keybd/mouse combo. Curious thing after flashing, Box will not boot into recovery via toothpick method nor will it accept a factory data reset. Any ideas or advice. Thinking I may want to flash with custom ROM someday.
Thx - JF -
I always use the petrus reboot reboot app to boot into recovery if your rooted try it its much better than using a tooth pick https://play.google.com/store/apps/d...s.reboot&hl=enPlease consider making a Donation to freakTab
Sounds like your recovery is messed up.I think you could put the recovery on a sd card & it would boot into recovery from the sd cardPlease consider making a Donation to freakTab
Have you got the factory_update_param.aml on the sd card too.
put the factory_update_param.aml & the recovery.img on the sd card & it should boot into recovery from the sd card
Other than that maybe someone else can help more or you could download finless rom http://www.freaktab.com/showthread.p...EM8-Square-Box & try to flash that rom using the instructions in the packagePlease consider making a Donation to freakTab
I've installed finless Bob's 2.1 ROM on a couple of boxes with no issues. Since flashing with MBOX_112k4_sdcard.zip package I cannot get back in to recovery. Like I mentioned the box is running fine, it's just odd that I can't get back to recovery. Since this box has no OTG I'm running out of options.
Sorry iv only just noticed what box you have you need to be looking here http://www.freaktab.com/forumdisplay.php?189-ENY-Acemax-EM8-(square)-EM6Q-etc- Devices
I assumed you had a round box since your in this thread Beelink AML devices - S82/M8 (round), MXIII,
I will move this thread to the correct place then you may get more help,Please consider making a Donation to freakTab
Thanks for moving to proper thread, although it's a bit confusing. It is a square box but the model reported in the settings is a M8 kitkat, build K0T49H and the box seems almost identical to the MXIII. I have another
M8 box with finless bob's 2.1 ROM. I did run across an Amlogic burning tool, going to give a go with that.
There are currently 2124 users online. 2 members and 2122 guests.
