I can not run hdmi cec. xbmc (13.3 and 14 for android) works but the videos have stuttering. SPMC (play store or 14 beta 2) have same problem. I do I play videos from my server nas with smb. my network is all gigabit. I followed the forum but have never managed to solve the problem. thank you
tronsmart problem
tronsmart problem
Hi! I hope you help me. I have a tronsmart orion r28 pro. I have tried many firmware (stock 108k, 110k, 11k wasser 2.0.0 / 1/2/3/4/5 and open chamaleon hour) but I can not make it work.
I can not run hdmi cec. xbmc (13.3 and 14 for android) works but the videos have stuttering. SPMC (play store or 14 beta 2) have same problem. I do I play videos from my server nas with smb. my network is all gigabit. I followed the forum but have never managed to solve the problem. thank youTags: None
Normally it should be fixed with wasser 2.0.5 or the open chamaleon hour port...
Did you also tried this http://www.freaktab.com/showthread.p...l=1#post266312RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostNormally it should be fixed with wasser 2.0.5 or the open chamaleon hour port...
Thanks for the reply . I have already tried the new wasser 2.0.5 but does not solve the problem
Originally posted by gino90 View PostHi! I hope you help me. I have a tronsmart orion r28 pro. I have tried many firmware (stock 108k, 110k, 11k wasser 2.0.0 / 1/2/3/4/5 and open chamaleon hour) but I can not make it work.
Originally posted by gffmac View PostTry SPMC on latest Wasser with RKLIBSTAGEFRIGHT and MEDIACODEC enabled and disable LIBSTAGEFRIGHT hardware acceleration, works fine like that on my pro r28.
I add the following line into the advancedsetting.xml to disable smb statistic on files.
This settting improves a lot of smb performance in XBMC. I hope this can help you.
<samba>
<statfiles>false</statfiles> <!-- Set to false to disable smb stat() on files to speed up listings of large directories (over slow links) -->
</samba>
There are currently 2605 users online. 0 members and 2605 guests.
