Can someone help me?
Hello,
Yours Device is not Broken. You need to put it in Mask Rom Mode.
To do this Open the Device and Short Pin 5+6 on Nand Chip then Connect it to the Computer.
Now it should regonize your Device in Mask Rom Mode.
Then you can Reflash it.
If you want a KitKit Rom Running you need only a different Kernel because the J22 use a different
GPIO Port.
Kernel you find here:
http://www.freaktab.com/showthread.p...All-(well-most!)
And take the Kernel for AP6210-Alt.
Regards
Neomode
p.s. i bought this device http://www.aliexpress.com/snapshot/6...65408179872307 but it restarted non stop and thats why i flash it
There are currently 1716 users online. 1 members and 1715 guests.
