OTT M8 box
Originally posted by RISCy Dude View PostI do not have the OTT M8. But in the box I do have(UT3), the A/V jack does output audio and video. Is yours not doing that?
I'm using this cable which I think is the correct one?
Code:http://www.amazon.co.uk/gp/product/B003OSPS8Y?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Originally posted by freforall View Postfor the setting i don't know?? such as said i use hdmi with my box and i never use composite but this cable is ok and for the setting another member use composite can confirm is setting or not
According to a review I found online it should auto choose the AV if the HDMI is not plugged in,but no luck yet,
Thanks for the input
Originally posted by wiz569 View PostQuick question guys, is the AV port supposed to output audio and video or is it for some other use?
try to change the outputs ...
Hope this helps ....
Originally posted by xc0rpi0n View Postalready experienced the AV in m8n with 2 cables, one gives and the other not, but the cable worked, the video output is the color red, and yellow and white is the audio ......
I only have the one cable
No real standards like Red=R, White=L, Yellow=Vid....
Originally posted by wiz569 View PostNo joy I'm afraid,video is supposed to be yellow and red/white for audio
Some users have said, "pulling the plug out a wee bit", made their cable work.
There is no standard on these cables for video. My cable was purchased originally for an old video camera, the same cable would not work on my iPod Video's headphone/A/V jack. Some have 15mm pins(plug face to tip), while others(my UT3) use one that is 18mm. I would think a device that uses a jack designed for a 15mm A/V cable and wants to remain compatible with stereo cables, will have to split the ground section(closest to plug body) into two separate conductors. And assign the jack's ground to the plug's 2nd closest conductor to the plug's body. The extra conductor(video?) will be closest to the plugs body(face). Or vice versa.
I like the way the Wetek box has a jack assignment directly on the case, near the jack.
Good luck.
Originally posted by wiz569 View PostYep HDMI is fine but I need to use the AV port for the TV in the computer room,so i can play around with stuff,without bothering the other half lol,
Re: OTT M8 box
Originally posted by RISCy Dude View PostDoes the monitor in the computer room have an HDMI input? Also, I have heard HDMI to DVI adapters will work. Some things are difficult to see on our old CRT TV when I play the UT3 through it(same when I run my PC through it). The screen has to be scaled for the picture to be in proportion. Works OK for vids, Hulu and some games. I usually have to pinch-zoom(trackball w/push button scroll wheel) webpages to read them clearly. All things considered, using a CRT TV works in a pinch. But a PC monitor or HDTV is much more enjoyable.....by far.
but using a HDMI to dvi adaptor it just gives a video mode not supported message when connected,
I only want it to work this way so I can mess around with the box,try different ROMs etc without disturbing swmbo
Cheers guys
There are currently 1105 users online. 0 members and 1105 guests.
