I've Messed Up My Recovery Somebody Help!?
    When I boot into recovery, the screen goes red for 3 seconds or so, then the recovery comes up and when I move mouse or scroll, the selection goes crazy, like from up to down and I can't do anything just unplug power and boot to rom again...
    Is there a way for me to go back to stock recovery and clean everything like it was, because I was searching for some recovery for my M8N to backup a rom and probably installed wrong one. I really need to clean this box and get normal recovery like was in stock.
    Please Help!
    Please Help!
    why can't you use the remote to navigate, certian mouses can be finiky as you mention slight move the mouse scrolls like crazy
    Bugs are Sons of Glitches!
    JustMe
      Have someone with stock recovery run "dd if=/dev/block/recovery of=/data/recovery.img"
      That will give them an img in the /data/ directory. The compress and send to you
      Then you save to /data/ directory and run "dd if=/data/recovery.img of=/dev/block/recovery"
      If you ever test something run that first one to get a backup.
      Dont forget SU before the dd commands.
        Sorry, but I'm completely not familiar with what you're saying, I understand things in android, but I guess I'm a noob in this category...
          Run those commands from a terminal emulator...i would do it but i dont have that device. Maybe someone reading will help out.
            Thanks, let's hope someone will respond, btw should I get zip or .img file?
              If they zip it will be a lot smaller and easier to transmit.
                Mouse is VERY responsive in the recovery, maybe that explains what you got. Did you try to move the mouse downward very slowly?
