Internal Storage full
Hi all, after being told there was not enough space to install kodi 14.1, I checked the storage info. It says that there is nearly 5gig taken up by misc and when I click on it, it is blank so I have no idea how to clear it. Any ideas please as I only have a couple of apps installed?M8N Quad Core Android 4.4
JustMe v1.5 ported v2Tags: None
The files are hidden, Ive seen this several times, install es explorer and set your options to view hidden files then delete the temp directory in Kodi. If you dont want to install es explorer use the inbuilt browser but you wont see the hidden files.
Originally posted by elgrego View PostHi all, after being told there was not enough space to install kodi 14.1, I checked the storage info. It says that there is nearly 5gig taken up by misc and when I click on it, it is blank so I have no idea how to clear it. Any ideas please as I only have a couple of apps installed?
Originally posted by cadurling View PostYes Es Explorer, in the left hand side list under "Tools" turn "Show hidden files" ON.M8N Quad Core Android 4.4
There are currently 1707 users online. 0 members and 1707 guests.
