Cube T9 and Office
    Cube T9 and Office
    The Cube T9 is almost perfect, but I am still looking for an app that opens and views office apps smoothly. I use my T9 for business, and so far this is the main area that my T9 does not measure up to iPad.
    I am using Docs To Go and have tried a few others, but they all seem to be glitchy at times.
    Could some of this be helped by buying the pro version and removing the ads? If not, I do not wish to throw my money away.
    Any others hints or suggestion of an app welcome.
    Thanks.
    Cube T9; Pipo M8 Pro (on life support); LG gPad
    Thanks.
    I don't have my T9 yet. But if it has full Google Play store, Microsoft just released Office apps for android . you can search for Microsoft Word app in the play store. Before this release, I used Kingsoft office, now called WPS Office.
      Thanks. I will give that a try. So far Office 8 has been the best, but it is not as smooth as I would like. I think the ads on the free version may be slowing it some.
      Thanks again!
        Finally went back to DocsToGo. It works well, and will do better, I am sure - when I upgrade and get rid of the ads.
          I'm using MS office for android, it is very smooth on my P4. before I was using WPS and Ms office 360, never used them again.
          M8pro
          M9pro (current tab)
            MS Office looks to be incompatible with the T9. I could load the individual components of Office (maybe), but I would lose the convience of having all my files being opened in one place.
            Dang!😐
