you wouldn't need to start at zero, i work in IT as a network administrator.
Explaining Why and Where to Use It:
so i decided to want an android stick for the 3rd (not so smart)tv.
A) id only use it to stream media from my nas with a plex server running on it.
B) id like to watch those videos in full hd, without any performance loss, frame-****-ups or the likes.
C) this device wouldnt be used for games.
D) it should be able to surf the web (occasionaly) and read a mail or two.
E) wifi without any problems would be perfect / Ethernet (RJ45) possibility would be Great (usb to rj45 female adapter currently present at home)
F) even if those requierements are not really fancy (i guess) id like to have a device with enough power to easily get all those things done and then some
G) id much prefer a "stick" over a "box"
H) id like to spend under a 100€
Questions:
1) is the overheating/generall heat still a problem with those sticks?
2) is there still a WIFI signal problem with those sticks (lags when streaming 1080p)?
3) does it play a big role if android 4.2 or 4.4 or even 5 (if possible on those sticks)?
4) why are there so many ROMS (modified operating systems i guess)?
4b) are those ROMS only available to fix bugs, or do they free some additional features?
5) i honestly dont know any of those stick vendors. "andoer", "beelink", "mystore365" and so on. which ones are relieable and legit?
6) i saw about 8 different vendors making a model called mk808 with the exact same specs - are there differences between them ? - and if so - how do i find the right/best one ?
7) what means MKxxxi/ii/iii/v/ ?
The Obvious:
which model can you guys prefer based on your knowledge by using the prefered device. (by keeping in mind my described field of needs)
i want to thank you guys already for your hopefully helpfull answers!
p.s.: as far as i know there are more than one cpu's which seemed to me right now, are the biggest differences, please dont let this thread for seeking help turn into a fan war
thanks!
