X5 Kitkat v2.2.0 Community Edition
    MINIX Forum "Community Edition" Kitkat 4.4.2 for X5
    - You need to manually flash this firmware with the USB Flashtool
    - All the tools will be provided in the download .rar file.
    The future of CE;
    This is not really a CE release anymore.
    This firmware is build as an "Official MINIX" release, so it has all proper MINIX logo's and background.
    The reason we release it under "custom roms" is because MINIX has to approve it first.
    Hopefully we can copy this topic to Official section soon. ( or we might do that on next release )
    Changelog:
    - Huge HLS revision
    - Camera fix
    - TCP buffer adjusted
    - Network fixes
    - Powermenu, removed power off. (x7mini branch)
    - HDMI changes
    - MINIX Official build
    Other;
    - Finished X5mini branch ( currently available: X7,X7mini,X5,X5mini)
    - rk3066 random mac fix
    - sleep suspend fixed( wakeup from USB Remotes / IR remote / Powerbutton )
    - fully renewed audio bitstream system + audio input fix ( show usb audio input devices )
    - Screen settings all on one page
    - additional VPN/networking config ( IPIP,L2TP,PPP )
    - removed PIN for VPN settings
    - VPN wifi hotspot fix
    - Removed google searchbar from desktop
    - long press menukey to hide/unhide systembar
    - recovery show UI + Null pointer fix
    - USB storage announcements framework renewed
    - wifidisplay / miracast HDCP key integration ( not functional yet )
    - libffmpeg and RKffplayer updated to version 8-12
    - fixed RKexplore app
    - fixed WifiDisplay app
    - Small HLS fix ( not much yet )
    - Updated Gapps ( Google Apps )
    - Google sync issues fixed
    - new kernel logo
    - etc.
    Download link:
    WARNING!! WARNING!! WARNING!! NOT EASY TO GO BACK TO 4.2!!
    (You need to use RK flashtool, do not try to flash it like an OTA update.zip !)
    Available Updates:
    Kitkat CE - root update
    Kitkat CE - unroot update
    To install the available updates (this is not for the Firmware!) rename the downloaded file to update.zip and place at the internal flash drive root or USB stick root, android will find the update and request you to install.
    From the MINIX Forum Developers Team;
    @HardwareGuru
    @gufone
    @KAR
    Thx to all the team! My old device is happy
    Just a question... Before to flash, what is Kernel version, 1080p or 720p?
    Regards,
      Regards,
      it's 720p
        how to root. thanks
          Hi, thanks for the excellent works!! Could you tell me where I can download for X5 Mini?
            Originally posted by hoangan123 View Post
            how to root. thanks
            Read #post
              It will be ready real soon
                Originally posted by HardwareGuru View Post
                Read #post
                thanks you
                  Sometime auto reboot. Come Back to kitkat beta .
                    The future of CE;
                    Changelog:
                    - Huge HLS revision
                    - Camera fix
                    - Network fixes
                    - HDMI changes
                    Other;
                    - new kernel logo
                    - etc.
                    Download link:
                    Available Updates:
                    @HardwareGuru
                    @gufone
                    @KAR
                    can you share kernel this rom. thankss
                      If you dont know how to unpack/repack there is no use having a seporate kernel. Kernel is inside boot.
                        I will try with rom kitkat beta. Thanks for share..
                          Thank you very much for your hard work! flash it right now
                            Is there true 1080p kernel for this rom?
                              Yes see http://www.minixforum.com/index.php?threads/4030/
                              Kar
