MK3 Kodi 14.1 Problem
    Is anyone else having problems with Kodi 14.1? im on 112k stock, Kodi 14.0 booted but wouldnt play films, 14.1 has been released with alot of fixes but now boots and instantly crashes back to home screen.
    Cheers.
    UPDATE: All good, rebooted device and seems to be ok, no crashes as of yet.
    Cheers.
    Yes I have had problems with the way the Video played back on the MX BBC Plugin on the most recent Kodi 14.1 (Android Version). I don't know it its 'cause the Codecs haven't been "tweeked" or if it really is the fault of the Addon (i.e. MX BBC). But reverting back to the stock version of SBMC (XBMC 13.4). Everything is working again.
    I guess I'll just sit here, and chill to see what happens in 113k4 in a few days/weeks then.
    Makes me wonder if its a) Gonna be v5 Lollipop, and b) have the latest "tweeked" Kodi version.
    I soppose b) is likelier, though I gather a) isn't outta the question.
      Why use kodi 14 if there is an alernative that works
      Iam now using for a few months the tvmc addon on my tronsmart s89-h eazy install and seldom any problems and in less than 5 mins installed .It uses kodi 13.4
      its not mines nore have i anything to do with it i only use it and i can say that it works well 4 me
