Just ordered my Tronsmart AW80 Draco, do I have to set it up? New to this
Hi new to all these streaming TV boxes and ordered myself the Tronsmart AW80 Draco and need to know if I can use it right out the box or need to set it up? I'm mainly using it for kodi, and hopefully adding some old school Nintendo and new school games, is there a sticky on directions or where to start and what to do?? Thanks very much in advance for all help!Tags: None
Originally posted by Tommyjerzboy View PostHi new to all these streaming TV boxes and ordered myself the Tronsmart AW80 Draco and need to know if I can use it right out the box or need to set it up? I'm mainly using it for kodi, and hopefully adding some old school Nintendo and new school games, is there a sticky on directions or where to start and what to do?? Thanks very much in advance for all help!
I think no one is really happy with the stock rom. I use the homlet rom and i like it, but the others arent bad, too.
All the stickies that you need are here, just read some.
I would start by flashing a rom, configure android settings then configure kodi.
Its really not that hard and all the information is already written here.
YES, very bad, no just kidding, but it means, that you are new at Android
So I would do the following:
1. Have a look at http://www.freaktab.com/showthread.p...8-Boot-from-SD and use this rom http://www.freaktab.com/showthread.p...ock-20141219v1 at the SD.
(you can also use the SD way to flash a rom... then you have to use [Produce]... but there also exists a sticky http://www.freaktab.com/showthread.p...e-Flash-Method...)
2. Boot from the SD and play a little bit with the Android, also install app's (you need an account at Google Play Store) and if you sure the step you had done is ok and everything works as you want it should work, power of the device, remove the SD and reboot the internal Android at eMMC/NAND and reproduce the step... and then again and again and again...RK3288 Devices
- Overview BOX (LINK !)
There are currently 3423 users online. 1 members and 3422 guests.
