NO WIFI for MK808 at all
Found the cause of the problem and the wifi turn on problem resolved
Originally posted by Abyz View PostPlease try stronger power adapter. I had such issue when tried to work with 1A adapter.
I have found out the cause of the problem.
I have ordered for MK808 and they have sent me MK808B. I could not know this from the package as it says MK808. It is mentioned only in the price sticker. When I tried the item for the first time, it did not even work... just stuck up with GoogleTV display. The geekbuying support sent me a link to upgrade the firmware. With that firmware wifi totally failed to turn on. I did try with 3 other firmwares with no luck.
In another forum, one user suggested it could be due to the different model. Then I double checked the item package and made sure it is MK808B. I then downloaded the firmware from http://blog.geekbuying.com/index.php...ware-download/.
With this firmware, miniTV works fine.
There are currently 1416 users online. 1 members and 1415 guests.
