Android Remote App
I never tested it, but you can try to use the
DroidMote Server for windows http://www.videomap.it/download.htm
and at the Android device using the
DroidMote Client https://play.google.com/store/apps/d...roidmoteclient
Of course the also exists
VNC
At windows I would use TightVNC http://www.tightvnc.com/download.php
but don't know which version you should use as client at Android
TeamViewer
At windows http://www.teamviewer.com/de/download/windows.aspx
At Android https://play.google.com/store/search...mviewer&c=apps
etc...RK3288 Devices
- Overview BOX (LINK !)
There are currently 2730 users online. 1 members and 2729 guests.
