I have managed to boot into TWRP and taken an image which Ive said to USB and external SD Card.
When i then boot into TWRP on the 2nd box (I have the image i want to restore as a zip file on both the sd card and USB) i go to the Restore option but do NOT get a list of any zip files that are on either usb or sd?
I have ensured the zip is in the root of the SD.
I then go to the Install option and i can see the zip files on either the USB or ext SD.
I choose the zip on the sd card and it attempts to install.
however after a few seconds it stops and I get an error relating to MD5 creation
Now when i created the back up I ensured that i selected ALL options available to back up.
So im a bit stuck here. can someone help please
Bart
