MK808B Plus Pink Lines and black screen after
    Hi all,
    I received my stick. It's works fine. But after few on/off it's broke.
    When it's run - I see a pink line on TV and after 10 seconds - image is disappear.
    I tried flash 107 and 109 firmware(with USB_BURNING_TOOL), but result is the same.
    Can you help me?
    Originally posted by igorek-666 View Post
    Hi all,
    Can you help me?
    try different power supply and or cable
      I had one just like this, the HDMI socket not soldered properly,
      unless you have the tech know how, using hot air soldering iron etc....
      You`ll have to send it back to the seller for replacement.
