Minix Z64 BIOS videos
So does it means, that at the Android version with the x64 version of the BIOS that this is a 64bit BIOS?
Also some more settings at the IGD at the x64 version of the BIOS...RK3288 Devices
- Overview BOX (LINK !)
Could you please verify the following information?
MINIX NEO Z64A is having a 64-bit UEFI running a 64-bit Android 4.4.4
MINIX NEO Z64W is having a 32-bit UEFI running a 32-bit Windows 8.1
If Z64A has a 64-bit UEFI, can all 64-bit Linux distributions be installed easily?
Are the two provided flashable UEFIs interchangeable between the two devices, or are there some minor hardware differences? Having the ability to install either Windows 8.1 (Pro) 32-bit or 64-bit would be a nice option, although not critical.
Originally posted by loko View PostCould you please verify the following information?
True
Theoretically - but it depends on the installer used by the distro though
I'm not sure anyone wants to risk testing the interchangeability of the two UEFI BIOS as you could end up with a bricked device ... as in truly bricked!
Originally posted by linuxium View PostMy reply in red!
There are currently 2060 users online. 0 members and 2060 guests.
