No av sound
Originally posted by MisterX View PostI got a MXIII (s82 chipset, 2gb version). I'm running Openelec 5.0.0. Everything works fine, though when I connect it to an AV-tv, it doesn't give any sound. Does anybody know how to fix this? Thank you!
Are you using the supplied cable?
Originally posted by MisterX View PostI am using the supplied Av cable and there is no 3,5mm on a mxiii
Some boxes require the HDMI cable to be disconnected for A/V jack to work.
Are there settings in the MXIII for audio manager and is your display output set to auto?
I'm sorry I can't help, hopefully an MXIII user will chime in.
There are currently 1129 users online. 1 members and 1128 guests.
