Video on Demand - Silverlight performance
Originally posted by Trhuster View PostWhat temperatures do you have when streaming from TV4 Play or Viaplay? Both use sliverlight. Mabey you have thermal throttling problem like i had.
You would need about 2 Ghz ona all four cores.
I built a HTPC with Celeron J1900 for this case. It is nearly the same cpu like the Z3736f, but it can give 2 ghz (our cpu 1,57 with optimal cooling) to all four cores. On that PC everthing is smooth.
I hope that microsoft will optimize silverlight in the future for lower cpu usage.Last edited by Scooby-Doo; 23 February 2015, 15:57.
Originally posted by Scooby-Doo View PostI modified the igp grafic settings. Gfx boost -> enabled, instead of 32 I reserved 128 mb Ram for the graphics.
Result: Prime instant video silverlight HD streaming is fluent - now only in Internet explorer (nearly no more lags in rapid scenes).
I installed the 32bits version of silverlight.
/Mheel
Originally posted by Lucky Black View Postwhich of the two setting you changed
DVMT Pre-Allocated or DVMT Total Gfx Mem ?
Aperture size which value do you have ?
and GTT Size which value do you have ?
I don't want to mess up my PIPO X7
can you post a screenshot with your value for GFX Config thanks
I only changed Pre-allocated ram to 128 mb and enabled gfx-boost.
That´s it.
I had problems with Netflix streamingand now after having enabled GFX boost and increased the reserved graphic memory to 256 MB the streaming is much smoother. Thank you !
You indeed know this little amazing beast. It is the sound quality also that has won be completely.
What scares me is the huge number of possible settings in the bios.
I am completely lost there. But i will study here for sure.
Thanks again. Very kind of you. Kind regards, geppoWith the kindest regards, geppo
There are currently 2189 users online. 0 members and 2189 guests.
