Keyboard keys not working
Hello house was wondering if you could be of help to me. I bought the cubetalk 9x (a nice tablet I must say) and I've flashed Lepi's 2.0 ROM on it; however, since I bought it some keys on the physical keyboard that came with the tablet has refused to work, I even returned the keyboard and got another, but still got the same issue. Initially, I thought it was just a problem with the batch of keyboards supplied to the distributor until I tried using my Microsoft 800 wireless keyboard on it only to find the same issue. So am asking you as an experts in Android issue, if there is a fix for this problem and if yes, how do I go about fixing it? Thank you in anticipation of your response. Regards, FrancisTags: None
It has been discussed a lot.
this is due to the gesture enabled. I'm not interested on external keyboard so I didn't read well and I cannot help you more, but what I know is that this issue has been solved disabling gestures (if I remember well).
Read better the thread relevant to LEPI's roms or stock V.2.0 too (they share the same issue with external keyboards).if you appreciate my efforts this is the link for any donation:
Info for fixing external keyboard issue
If someone else is struggling with this issue, here is method to repair it. Check these links:
- Lepi's post with flashable repair zip-file
- ipi's post
- f1c's posts: post 1, post 2
- cabrinha's post
- goop's post under this post.Last edited by Vohukain; 07 April 2015, 09:31.
Originally posted by Vohukain View PostIf someone else is struggling with this issue, here is method to repair it. Check these links:
- ipi's post
- f1c's posts: post 1, post 2 and post 3
Ps. It is really shame that I can't edit the "Cube Talk 9X [U65GT] roms/recoverys/mods etc. list" thead's first post anymore to add these things to there. I have tried to contact moderators but got no answer.
Instead of modifying the generic.kl file, one can also create a keyboard layout file for that particular device using the following template. On my T9, the file name must be in small cap.
thriveforums.org ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf thriveforums.org alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Many thanks and best regards.
There are currently 2701 users online. 0 members and 2701 guests.
