MINIX X8 - H PLUS S812 DUAL CORE?
It's because of the core-management at the kernel... if more than 1 ore more cores need then more than 1 or more cores running otherwise they are at sleeping ...RK3288 Devices
- Overview BOX (LINK !)
It's a quad core... The power management on the firmware is set to hotplug which only turns on cores as they are needed... If XBMC is only showing 2 it's because you don't need anything more than that to run what you're running, but the other 2 cores will turn on automatically when they are needed.. If you have a rooted firmware you are able to install a CPU manager and change the power management so that the 4 cores are on all the time if you like..
what is the actual difference between the x8-h and the x8-h plus? sorry if it's been asked before... but on googling the specs, they look the sameSent from my Commodore 64 using Geos
My devices:
Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
Originally posted by Addyhash View Postwhat is the actual difference between the x8-h and the x8-h plus? sorry if it's been asked before... but on googling the specs, they look the same
I don't own either one.
Originally posted by RISCy Dude View PostI believe the main diff is the cpu. X8-H=S802-H. X8-H plus=S812. The S812 has decoder for h.265 encoded video. It may also offer GLAN.
H = HEVC Hardware (h.265) decode up to 2160p.
Non Plus Devices only have 10/100 Ethernet.
Non H such as the Neo x8 Plus which is otherwise also an S812 SoC), would only be able to decode HVEC h.265 IN SOFTWARE! Upto 720p
Originally posted by Ichijoe View Post
Plus = GigE ONLY....
There are currently 3391 users online. 4 members and 3387 guests.
