Does anyone else have any problem with loss of sound output on the UT3S after upgrading to official 2.0.6?
UGOOS UT3S 2.0.6 Official Firmware Problem
My Ugoos UT3S 4GB/32GB model does not output any sound via HDMI after I did OTA upgrade to 2.0.6 official firmware. Does anyone know how to downgrade back to 2.0.5b? I can't figure out how to connect the unit to my PC as it doesn't appear to have OTG USB. I am happy to do normal device recovery but I haven't been able to figure out how to do this either.
Does anyone else have any problem with loss of sound output on the UT3S after upgrading to official 2.0.6? -
Originally posted by SUPER77 View PostMy Ugoos UT3S 4GB/32GB model does not oDerived ny sound via HDMI after I did OTA upgrade to 2.0.6 official firmware. Does anyone know how to downgrade back to 2.0.5b? I can't figure out how to connect the unit to my PC as it doesn't appear to have OTG USB. I am happy to do normal device recovery but I haven't been able to figure out how to do this either.
Also, make sure you are using the USB drivers provided in the RK Driver Assistant.
Good luck.
BTW China is in holiday for a while, so support from Ugoos during this time, may not be available.
EDIT: Found the link to the USB info.
Originally posted by RISCy Dude View PostHello, I have not tried 2.0.6 yet, I have the UT3. In the Ugoos section, there is a post about which of the four USB is the otg. I think it was the one next to the card slot.
Good luck.
Thanks for that. Worked straight away. I restored back down to 2.0.5b. I would be curious if others have the same audio hdmi failure on their UT3S as I did. I informed UGOOS of the issue and they said they would investigate. Appreciate your feedback on the China holidays also.
Originally posted by SUPER77 View PostThanks for that. Worked straight away. I restored back down to 2.0.5b. I would be curious if others have the same audio hdmi failure on their UT3S as I did. I informed UGOOS of the issue and they said they would investigate. Appreciate your feedback on the China holidays also.
BTW It seems you are not the only one to experience loss of audio after 2.0.6.
I'm sure they will fix it.....in time(post holiday). 2.0.5.b works pretty well for me, though I like some of the changes shown in the 2.0.6 changelog.
I'm trying 2.0.6 now(not OTA). So far, no audio issues. Working well, though, I have not had much time on it.
I had done a dump of the stock rom (contains an already configured AndroidTools V2.33 and the parameter, uboot, misc, resource, kernel, boot, recovery, backup, cache, kpanic, system, metadata, userdata and radical_update... because of the 4GB userdata you need at least 5.2GB free disk space at your HDD and of course a lot of time during the flash process (~ 10 minutes))
Please, to avoid spam, use theat my download link...
Stock 2.0.5.b dump
RK3288 Devices
- Overview BOX (LINK !)
Hi all
I am very sorry about sound problem, now we trying to replay this situation. Unfortunately still no any devices with this problem here, but i don't deny this problem. It's exists. In any way i will publish some beta versions. Thanks all for suggestions and bug-reports.
Regards
Sam, Ugoos
There are currently 2186 users online. 0 members and 2186 guests.
