Today I've set up my custom cooling solution for my HPH box which now runs much cooler than before.
Here are my steps, together with images taken during the time of the whole procedure.
1. Searching through ****, I found one big 120mm near-silent cooler which almost perfectly fits the box size.
I've put four screws on each side of the cooler to serve as a stand, because the box will be on top of it, and the cooler will suck hot air above it and push it down and away from the box. I even cut tiny sponge pieces for every screw, so the cooler vibrations don't spread over the wooden table the cooler sits on.
Ofcourse, the cooler is powered via USB, so it can be easily connected to the box itself or an usb hub. I prefer the latter, because I have a hub with switches for every usb port, so I can turn the cooler on and off simply by turning the switch.
2. Next, I removed bottom "cover" of my box (@Tina: I guess my warranty is over now LOL), and then positioned it on top of the cooler.
Again, additionaly, I've put four sponge pieces in between to space out the cooler and the box a few more millimeters, and at the same time I prevented "slipperyness" when plastic box goes over the plastic cooler. I didn't want to glue them together, just in case I want to take everything apart.
3. And this is how it looks like in the end.
Not a piece of art, but gets the job done. And it sits behind my TV anyway.
For the "idling" time and low-powered tasks (music straming, internet browsing, watching movies, etc), the box is below cool levels, compared to even hot situations before. And that's inside my room with temperature of 20-25°C. During summer, when the temperatures will be 10-15°C more, this setup will come even more handy.
I still didn't test the setup with high-demaning games, but I certainly will, as the box is my main "gaming-rig"
So, what do you guys think? Would you improve something? I'll appreciate your suggestions.
And btw, has anyone figured out which temp file does CpuTemp Xposed module reads, so I can measure it?
