try your tuner ubuntu and which module uses.
open termianl and
lsmod
for example
dvb-usb.ko
dvb-core.ko
dvb-pll.ko
xxx ko?
etc.
later we create kernel for your tuner. I test at this time android tvheadend for minix x8-h plus. only hd channels periodic stutter some time. some h264 channels work any problem. android spmc perfectly play mpeg2 hw decoding than other kodi and xbmc
