New stock firmware for M8/M8N/EM8???
Originally posted by thekider View PostFor those that tried this ROM, are you also missing the 4K display setting options?
Do u have a 4K tv thats why u need it.??
Im.back home and checked what @thekider is missing.. "CONFIRMED"; there is no 4k video display on display settings ...i dont know why?maybe its a firmware issue?? but im not bothered by it as i dont have a 4k tv anyways and no plans of buying one in the future..
Anybody else using this firmware can also confirm..pls..i have the original M8N box with pcb no. V1.0 ...THANKS.Last edited by warlock09; 27 February 2015, 20:01.
Originally posted by warlock09 View PostI havent really checked @thekider...i will do when i get home.
Now having said all this, I wish I could actually test on a 4K tv because the other thing that occurred to me is possibly the options are hidden because I don't have a 4K tv.
Originally posted by thekider View Postsomething new to report on this ROM. I tried installing it on my friend's M8 and the network connections (ethernet and WiFi were disconnecting after 20mins (same symptom as acemax latest firmware being installed on M8 rather than M8N)
Originally posted by warlock09 View PostCan u confirm what pcb board no. Does your friends Square M8 have pls.[emoji1] [emoji106] ?. Looking back at this thread though, looks like userofthenet also had the issue on an M8. I don't think changing the channel listed in buildprop from 11 to 13 would fix this because the issue was also occurring with ethernet
Originally posted by zan. View PostI have the latest rom from Acemax, no serious problems so far and in general I am satisfied. Does it worth to upgrade to this rom?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postcan you test wifi when connected to wifi, switch of the unit via remote wait 15 to 20min and switch on leave the box alone and see if the box resets it self also do speed test before sleep and after wake up
I have not tested WiFi speed before sleep and after the wake up yet. Which app to use to test the WiFi speed?Last edited by zan.; 09 March 2015, 08:32.
Originally posted by zan. View PostI have the M8N tv box. I use the Acemax rom for more than a month and in general there is no wake up/WiFi disconnect/reset bug. Only once I observed this bug during this period (I had this bug all the time with the previous rom). After the box resumes from sleep mode all seems to work fine. A couple of times the system language changed by its own to chinese without a reason.
I have not tested WiFi speed before sleep and after the wake up yet. Which app to use to test the WiFi speed?Bugs are Sons of Glitches!
JustMe
Rom Fix
Inmediatamente al actualizar con esta ROM mi M8 comenzó a fallar el wifi y también la conexión por ethernet, se apagaba cada 15 o 20 minutos, pero ocupando esta rom http://www.droidsticks.co.uk/droidst...mware-download build 12/03/2015 se solucionó y quedó impecable, incluso puedo ver correctamente todas las películas compartidas en la red.
Espero les sirva.
Hello,
Immediately update this ROM my M8 began to fail the wifi and ethernet connection, turned off every 15 or 20 minutes, but occupying this rom http://www.droidsticks.co.uk/droidst...mware-download build 3.12.2015 was solved and was flawless, I can even see properly all network shared films.
I hope you serve.
Saludos.
There are currently 939 users online. 0 members and 939 guests.
