DB
auto start without pressing power button ?
Originally posted by dirtyballs View PostIs there a way to switch op de functionality of the power putton . so that the meego boots when it is put under power.
DB
BTW Exercise caution when adjusting things in the BIOS, you can possibly brick your box. However, the "what to do after power loss" setting should not be very risky, if at all.
Good luck.
Originally posted by dirtyballs View PostI seems to have bricked my meego.
I changed
State after G3 to S0 to S5
Don't do that, it will do nothing anymore. not even boot.
Led goes on, directly after power is put to it and then nothing.
I remember that I did something else different I did save and reset.
DB,
I am sorry you went through the problems.
Good luck.
DB
http://www.freaktab.com/showthread.p...777#post286777
There are currently 2297 users online. 0 members and 2297 guests.
