I've posted this question on the Minix forum, but unfortunately no one there has the knowledge it seems, but i only need some simple instructions.
What is the proper way to re-root?
I've upgraded the firmware from 002a to 12/24 (002b?) via FOTA and then to final 003 (also via FOTA) while having root, and all went well.
Box is working perfectly fine on the last firmware (003fw dated 20150205 + latest slow-motion hotfix via FOTA, dated 20150207).
When I check if rooted, the app root checker still says the box is rooted, and busybox is also properly installed, but none of the apps that need root work (like titanium backup, foldermount or set-cpu).
I've tried to re-root with Gufone's root app, which installs without problems whatsoever, but when I boot to android the superuser app says the binary needs to be updated, but fails to update/install it somehow.
What do I need to do to get root back the proper way?
Thanks!
p.s. I forgot to mention, due the simplicity of the superuser app I installed SuperSU in order to have more control, (before upgrading from 002 to 003fw) but i don't think this makes much difference what superuser app is currently installed on my box as there is no binary anyway
