when is the ugoos ut3s getting hdmi output of 4k 50/60 fps support in the software?
Originally posted by mo123You have to use a TV with 10-bit HDMI 4K support to use 60hz 4k.
Read up on it here http://www.freaktab.com/showthread.p...-60Hz%28FPS%29
Originally posted by gjvk70 View PostHi Jeroentje,
Any progress on this? I have the same issue with the U3S and the Panasonic 48AX630...
Regards,
Gerard
Note: hdmi poort 1 gebruiken deze alleen ondersteund het volledige 4:4:4 color dept.spectrum
laat ff weten of het gelukt is
Groetjes jeroen
We which where not from Netherlands would also like to know what you wrote...
So please, board language is English...
Gerard I have good news for you if you have ut3s. It is a setting on your TV. I myself found out. Go to the menu, then Settings, and then put him under hdmi autom.instellen op.modus 2 and then start ugoos ut3s and voila there zijn.alle resolutions available
Note: HDMI port 1 use it only supports the full 4: 4: 4 color dept.spectrum
let ff know if it worked
Greetings jeroenRK3288 Devices
- Overview BOX (LINK !)
Originally posted by jeroentie View PostGerard ik heb goed nieuws voor je als je ut3s hebt. Het is een instelling op je tv. Ik ben er zelf achtergekomen. Ga naar het menu en dan instellingen en zet dan onder hdmi autom.instellen hem op.modus 2 en daarna ugoos ut3s opstarten en voila daar zijn.alle resoluties beschikbaar
Groetjes jeroen
Thanks for sharing your solution. I tried this,but unfortunately no luck.
Also tried changing the HDCP settings but.....
I connected the Ugoos UT3S to HDMI-1.
Do you have other suggestions?
Thanks in advance,
Gerard
I
Thanks in advance,
Gerard
Originally posted by jeroentie View Postassume you are on the latest 2.06 firmware hdcp settings didn't change it for me either. Modus 2 has to be it. When i change it back to 1 i looses 50 en 60 fps.again. we have.the.same tv only another inch. so you still.have to look in that direction. Which cable are you using. Try the original ugoos flat cable it has to be high speed
My apologies it took a while! Very busy..
You are right, I am on the latest firmware. I was using the original cable, but also tried another highspeed cable. No luck :-(.
Regards,
Gerard
Please see this guide. It may have the answers you are looking for. Was the cable capable of 18Gbps?
Originally posted by Rayzin View PostPlease see this guide. It may have the answers you are looking for. Was the cable capable of 18Gbps?
I am not sure about the cable, but Jeroen used the cable provided by Ugoos. I also used this cable but with no luck.
Regards,
Gerard
@gjvk70. You have read the guide for Panasonic TX-55AX630E but not thorough enough.
On page 31 in "Valid 4K format (HDMI)" there is a note:
Valid 4K format varies depending on HDMI terminals as following.
HDMI1:
30, 25, 24p / 4:4:4 (8 bit, 10 bit, 12 bit)
50, 60p / 4:4:4 (8 bit)RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View Post@gjvk70. You have read the guide for Panasonic TX-55AX630E but not thorough enough.
As you can clearly see 10 bpc mode is only avaible at 30fps max.
Hi Gormar,
Thanks for replying. Sorry I missed this, but to be honest I don't understand all these details.
How do you explain Jeroen managed to enable this mode with the same Ugoos, same cable and same TV (only different resolution)?
Best regards,
Gerard
Originally posted by gjvk70 View PostHow do you explain Jeroen managed to enable this mode with the same Ugoos, same cable and same TV (only different resolution)?
1. He didn't achieve 4K at 50/60Hz on that TV and RK3288 device but it only seems to him that he done it.
2. Panasonic TX-xxAX630E manual is wrong.
Without proof I must say that for me the first option is the most probable.
After long time: Or there is third option. RockChip misinform about RK3288 HDMI 2.0 interface and need of display with 10bit color depth capabilities at 60fps. From my investigation I can conclude with 100% certain that RK3288 HDMI 2.0 display interface support 8 bit per color channel and choose it exclusively. Only downfall is that at present time it can not output other than YUV 4:4:4 or RGB888 colorimetry (yuv4:2:0 is out of the question)Last edited by Gormar; 10 March 2015, 17:04.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostThere are only two mutually exclusive explanations:
I have not checked 50 or 60 fps at 10 bit(i have no material yet?
For the unbelievers i can make some photos of my screen
There are currently 2781 users online. 0 members and 2781 guests.
