X5mini Kitkat v2.2.0 Community Edition
Originally posted by KAR View PostMini does not have BT so will never ever work
Kar
Reference
Hello and thank you for making this ROM. I just wish I could download it. Does anyone have a backup of this somewhere that they could post a link to?If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
Originally posted by KAR View PostMINIX Forum "Community Edition" Kitkat 4.4.2 for X5mini
- You need to manually flash this firmware with the USB Flashtool
- All the tools will be provided in the download .zip file.
The future of CE;
This is not really a CE release anymore.
This firmware is build as an "Official MINIX" release, so it has all proper MINIX logo's and background.
The reason we release it under "custom roms" is because MINIX has to approve it first.
Hopefully we can copy this topic to Official section soon. ( or we might do that on next release )
Changelog:
- Removed 1080i From HDMI mode in X5 Series Branch (not supported in Rk3066 devices)
- Fixed Camera Drivers/Brightness (during test all used Cameras were detected)
- Fixed Spdiff pasthrough
- Huge HLS revision
- Camera fix
- TCP buffer adjusted
- Network fixes
- Powermenu, removed power off. (x7mini branch)
- HDMI changes
- MINIX Official build
Other;
- Finished X5mini branch ( currently available: X7,X7mini,X5,X5mini)
- rk3066 random mac fix
- sleep suspend fixed( wakeup from USB Remotes / IR remote / Powerbutton )
- fully renewed audio bitstream system + audio input fix ( show usb audio input devices )
- Screen settings all on one page
- additional VPN/networking config ( IPIP,L2TP,PPP )
- removed PIN for VPN settings
- VPN wifi hotspot fix
- Removed google searchbar from desktop
- long press menukey to hide/unhide systembar
- recovery show UI + Null pointer fix
- USB storage announcements framework renewed
- wifidisplay / miracast HDCP key integration ( not functional yet )
- libffmpeg and RKffplayer updated to version 8-12
- fixed RKexplore app
- fixed WifiDisplay app
- Small HLS fix ( not much yet )
- Updated Gapps ( Google Apps )
- Google sync issues fixed
- new kernel logo
- etc.
Download link:
WARNING!! WARNING!! WARNING!! NOT EASY TO GO BACK TO 4.2!!
(You need to use RK flashtool, do not try to flash it like an OTA update.zip !)
Available Updates:
Kitkat CE - root update
Kitkat CE - unroot update
Kitkat CE - 1080p update (only for x5 series)
To install the available updates (this is not for the Firmware!) rename the downloaded file to update.zip and place at the internal flash drive root or USB stick root, android will find the update and request you to install.
From the MINIX Forum Developers Team;
@HardwareGuru
@gufone
@KAR
There are currently 2069 users online. 0 members and 2069 guests.
