I am hoping somebody out there will have a solution for this issue I have, I can no longer turn my WIFI on, it just says turning on and then just says error.
This happens on whatever ROM I use, it was fine for 10/11 months and no issues arose in that time with WIFI, has anybody come across this issue before/have a solution?
I will try the stock ROM but I will still have the same issue I suspect.
