HOMLET V2
DOWNLOAD LINK
(CURRENTLY UPLOADING TO ROM FOLDER):
https://mega.nz/#F!1ooWkBpY!U5paX2CgumqSuPG8JxppuQ
HOMLET V2 - A rom with modifications similar to dovless 1.13/1.18
Based on :
[SIZE=3][B] "Stock firmware" Tronsmart[/B][/SIZE] [I]version 1 of [B]12/19/2014[/B] a.k.a.:[/I][SIZE=2][COLOR=#0000ff][B] CX-A99-A80-4.4-6335-[/B][/COLOR][COLOR=#ff0000][B]2014[/B][/COLOR][COLOR=#800000][B]12[/B][/COLOR][COLOR=#ff0000][B]19[/B][/COLOR][COLOR=#0000ff][B]v1[/B][/COLOR] [/SIZE]
BACKUP/RESTORE SCRIPTS FOR USB KEY PREPARATION (data.tar) :
backup_restore_scripts.zip
[SIZE=1]1) [B] OVERCLOCK[/B] (672 MHZ vs 600 for RAM and 1800MHZ vs 1600MHZ for CPU).
2) [B]RESTORE USERDATA AND AUTO INSTALL OF ANY APK [COLOR=#ff0000][I](YOU NEED A PREPARED USB KEY FOR THIS OPTION)[/I][/COLOR][/B]
3) [B] TWEAKS VIA SUGGESTED BUILD.PROP ADDITIONS & powervr.ini changes[/B] [COLOR=#ff0000][B][I](thx to 4pda.ru users)[/I][/B][/COLOR]
4[FONT=microsoft sans serif][SIZE=1]) [/SIZE]This rom contains the following modifications applied to CX-A99-A80-4.4-6335-20141219v1:
[B]TWRP RECOVERY[/B]
5) [B] COSMETICS/DISPLAY TWEAKS & VISUAL CHANGES[/B]
-100%/FULLSCREEN by default: script to push settings to settings.db (NEED PRIOR ACCESS TO "SETTINGS MENU" TO WORK, QUICKLY ENTER SETTINGS ON FIRST BOOT)
[COLOR=#000000]-Changed [B]bootlogo [/B]to neutral/anonymous img (I was mad/sad when users like my parents were cursing a this "Finless" box, cause Finless only made it better!)[/COLOR]
-Changed [B]bootanimation [/B]to minimalist looping google gears[/SIZE]
[COLOR=#ff0000][FONT=microsoft sans serif][SIZE=1] [COLOR=#000000][B]NAVIGATION BAR IS ON[/B][/COLOR][COLOR=#ff0000], USE ROM TOOLBOX TO DISABLE[COLOR=#ff0000]: [/COLOR][/COLOR][COLOR=#000000][B]"qemu.hw.mainkeys = 0"[/B] ==> SET TO[/COLOR][COLOR=#ff0000][COLOR=#ff0000] [B]1 [/B][/COLOR][/COLOR][/SIZE][COLOR=#000000][B][SIZE=1]TO REMOVE BAR[/SIZE][/B][/COLOR][/FONT] [/COLOR]
NOTES & DISCLAIMER:
* This ROM was made for testing and educational purposes. * It is not intended for commercial use. * Software included may be subject to copyright. * Flash this ROM at your own risk. Developer is not responsible for what you do on your device. 1) For taking advantage of some of the features added to this ROM you will need a USB key. 2) Please consults "installation" portion of this document to resolve issues encountered 3) [COLOR=#ff0000]All tests are performed on:[/COLOR] Maxone CX-X8 4GB/32GB model [URL="http://www.geekbuying.com/item/Maxone-CX-X8-A80-Octa-Core-Android-Mini-PC-XBMC-4K-4GB-RAM-32GB-ROM-2-4G-5G-802-11AC-WIFI-USB-3-0-BT-H-265-SATA-1000M-339872.html"]http://www.geekbuying.com/item/Maxon...0M-339872.html[/URL]
[SIZE=1]Using [B]Rom Toolbox[/B] [I](lite / free version is sufficient)[/I]
via [I][B]"CPU"[/B][/I] button set:
* governor:[B]performance[/B]TIPS FOR ADDED BENEFITS:
[SIZE=1] apply and set [COLOR=#0000ff][B][I]"apply on boot[/I][/B]"[/COLOR][/SIZE]
USBKEY root directory structure for automated restoring/installation
[SIZE=1]0) this rom can make use of a USB key to restore you prefs and install any provided apk 1) prepare your USB key with desired files, following this naming/structure convention: [B] USB KEY ROOT FOLDER:[/B] [IMG]http://i.imgur.com/KWhh3Zm.png[/IMG][/SIZE] [LIST][*][SIZE=1] [B]data.tar[/B][/SIZE][LIST][*][SIZE=1][COLOR=#ff0000][B]can be created with the provided script[/B][/COLOR] [B][URL="http://www.freaktab.com/attachment.php?attachmentid=9724&d=1420974504"]backup_restore_scripts.zip[/URL][/B][/SIZE] [*][SIZE=1]import and then run [B]data_backup.sh [/B]using rom toolbox, and [B]with your USB key plugged in.[/B][/SIZE] [*][SIZE=1](edit [B]data.tar[/B] [I](the raw backup made by [B]data_backup.sh)[/B][/I] to only contain desired folders) (useful for XBMC/KODI/TVMC/SPMC add-ons and settings restore)[/SIZE] [/LIST] [/LIST] [LIST][*][SIZE=1][B] /preinstall/mynamedoesnotmatter.apk[/B][/SIZE] [*][SIZE=1]/preinstall/anynameaswell.apk[/SIZE] [*][SIZE=1]/preinstall/etc....apk[/SIZE][LIST][*][SIZE=1]put all the apk you want to have installed during [COLOR=#0000ff][B]1st boot[/B][/COLOR] [/SIZE] [/LIST] [/LIST] [LIST][*][SIZE=1][B]/settings/com.android.settings_preferences.xml[/B][/SIZE] [*][SIZE=1]/settings/[B]accounts.db[/B][/SIZE] [*][SIZE=1]/settings/[B]wpa_supplicant.conf[/B] [/SIZE] [/LIST] [SIZE=1] WHERE: "[B]data.tar[/B]" is your backup TAR file of "[B]/sdcard/Android/data/[/B]" application folders (XBMC/KODI for example), [COLOR=#ff0000][B]can be created with the provided script[/B][/COLOR] [B][URL="http://www.freaktab.com/attachment.php?attachmentid=9724&d=1420974504"]backup_restore_scripts.zip[/URL][/B] "[B]preinstall[/B]" folder contains the APKs you would like to have installed on 1st boot "[B]settings[/B]" folder contains your desired preferences files (UI, accounts & Wifi are supported at the moment, see above naming requirements) [/SIZE]
THESE IMGs ARE NOT SUITABLE FOR "STARTUP MODE"
[COLOR=#800000][B]PHOENIXCARD CRASHES WHEN USING THIS MODE WITH ALL MY IMGs[/B][/COLOR] [COLOR=#008000][B]TO FIX YOUR IMAGE FOR STARTUP MODE (BOOT FROM SD) IN 3 STEPS:[/B][/COLOR][INDENT]Use imgRePacker_205 : 1) drag, "draco_aw80_dovless_1.09.img" on "imgRePacker.exe". 2) delete ROM draco_aw80_dovless_1.09[B].img[/B]. 3) drop your [B]folder [/B]"draco_aw80_dovless_1.09.[B]img.dump[/B]" on "imgRePacker.exe". [/INDENT] [B] Source:[/B][URL="http://www.freaktab.com/showthread.php?21694-ROM-DOVLESS-1-09-%2818-01-2015%29-based-on-Finless-ROM-1-1-BETA2&p=273578&viewfull=1#post273578"]http://www.freaktab.com/showthread.p...l=1#post273578 [/URL] [B]If rom still does not boot from SDCard,[/B] [B]rebuild and image, reflash it to sdcard and try again,[/B] [I]2nd try worked for 2 users.[/I] [COLOR=#0000ff][B]If problems with your SDCARD[/B][/COLOR][B] format it[/B] using - "[B][I]HP USB Disk Storage Format Tool 2.2.3[/I]"[/B] (free tool, google it), then try again.
CREDITS
[SIZE=1][COLOR=#0000ff] [B]This ROM takes some inspiration from methods and changes implemented in "Finless-ROM-1-1-BETA2[/B]"[/COLOR] [B]* Credits & Kudos should go to "[COLOR=#ff0000]Bob aka Finless[/COLOR]" for his work, the ROM & his continuous contributions and involvement[/B] [B]* If you like this work, please [COLOR=#800080]donate to Bob![/COLOR][/B] @ [URL="https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=3GN5JFZXXQLCA"]https://www.paypal.com/cgi-bin/websc...=3GN5JFZXXQLCA[/URL] * Original ROM discussion thread:[URL="http://www.freaktab.com/showthread.php?20692-NEW-Draco-AW80-Finless-ROM-1-1-BETA2"] http://www.freaktab.com/showthread.p...-ROM-1-1-BETA2[/URL][/SIZE] [SIZE=1]Furthermore, [B]the team @[/B] [COLOR=#ff0000][B]4pda forum[/B][/COLOR] is [B]working really hard[/B] with tests and research to compensate Allwinner/tronsmart lack of support. [B]A special,[COLOR=#0000cd] big, and deserved thank you [/COLOR][/B]! [B]to them for their work[/B] and particularly in regards to [B]build.prop / CPU / powervr.ini / sdcard[/B] and much more , the following users deserve [B]full credits[/B] and [B]attribution [/B]for their [B]discoveries and general awesomeness[/B]: [COLOR=#ff0000][B]* buhsoft2006 * kuzzman * k100Pipo[/B][/COLOR][/SIZE]
OTHER AND OLDER VERSIONS
[SIZE=1][B][COLOR=#0000ff]Finless [/COLOR][/B][COLOR=#0000ff][B]ROM version:[/B][/COLOR] [URL="http://www.freaktab.com/showthread.php?23126-ROM-DOVLESS-1-13-%2812-02-2015%29-based-on-Finless-ROM-1-1-BETA2"] http://www.freaktab.com/showthread.php?23126-ROM-DOVLESS-1-13-%2812-02-2015%29-based-on-Finless-ROM-1-1-BETA2[/URL] [COLOR=#0000ff][B]Tronsmart ROM version:[/B][/COLOR] [URL="http://www.freaktab.com/showthread.php?21853-ROM-DOVLESS-0-01-based-on-Finless-ROM-1-0-BETA"]http://www.freaktab.com/showthread.p...s-ROM-1-0-BETA[/URL] [COLOR=#0000ff][B]Previous thread[/B][/COLOR] [URL]http://www.freaktab.com/showthread.php?21853-ROM-HOMLET-V1-%2820-01-2015%29-based-on-CX-A99-A80-4-4-6335-20141219v1-img[/URL] [COLOR=#0000ff] [B] Previous releases[/B][/COLOR] - v1 [URL="http://www.file-upload.net/download-10179497/draco_aw80_homlet_v1.7z.html"] http://www.file-upload.net/download-10179497/draco_aw80_homlet_v1.7z.html[/URL][/SIZE]
[SIZE=1]v2 - monthly refresh and update to latest tweaks - see dovless 1.13 & 1.18 v1 - initial release - initial release
