NEW CS918 2015 STOCK ROM FOR NEW PCB
I badly need help as I managed to brick a device that has the very same board as the one shown in the first post.
What I have done:
(1) installed and configured Kodi with a bunch of addons;
(2) rooted the device with RootGenius.
After I rooted the box, it died while playing an audio stream in Kodi. It switched off then never came back. Every time I press the power button, the lights will turn red for 6-7 seconds then turn off.
No output on HDMI, nor A/V. Even more catastrophic, the PC does not detect its presence on USB; it used to connect well in the past before the crash.
I also pressed recovery and power but with no effect.
The lights will also turn and stay red when I connect the USB cable (and the power adapter cable); this way the LEDs wont turn off but will not turn blue either...
Anyone can tell what seem to be the remaining options in this case? I am desperately trying to make it recognized by the computer on USB in order to flash it but it seems it has a serious power on problem for now.
Will it be an option to flash it by microSD card?
Many thanks.Last edited by aegyssus; 11 April 2015, 07:42.
What I have done:
Many thanks.
Originally posted by node View Post
Sorry to hear, I too had this trouble with one of my CS-918, and had to return it to the dealer to get it repair. I think the one option is to use UART & Putty to flash your ROM. Look around the forum, I am sure others did this on this model boxes as well.
I will check with the dealer too, but returning the item to China is costly and unsecure.. I had bad experiences in the past.
I just don`t understand if rooting the device could break anything...
Hi Guys,
I have the same problem, when power on the device the red led goes on for 3-4sec and the power off. No Blue light and nothing on TV.
I am trying to connect the box with RK Flash tool, i get the message below "Found RKAndroid MaskRom Rock Usb" but when i try to Erase IDB i get the ERROR:MaskRom must choose Loader for erasing.
What am i doing wrong?
my Box is:
Cs918 v7_0 #20141208
with RK3188-T/RTL8723BU/RK1000-S
ROM/Ram:8GB/2GB
after my Box was bricked i try different Roms,here is a List
working:
Cs918 v7.0.rar
8GB Stock Rom 2015 NEW PCB.7z
**with this 2 Image the Box starts,but i can not Mount the Nand Flash Rom,it ticks but nothing happens!
rk31_cs918_8723_150121_4.4_8g1g_v7.0.img
**this Rom works fine,sometimes Restarts
don't work:
B351_juebao_1080_2014_11_12
cs918_3188_8723_root_20140110
CS918_linda_918_root_8723_20140714
cyxtech_rk31_cs918_8723_141010_4.4_8G2G_fixed
cyxtech_rk31_cs918_8723_141013_4.4_8g1g
cyxtech_rk31_cs918_8723_150204_4.4_8g1g_v7.0_易亚特xb mc //seems to start,but hangs in Recovery screen
dump_cs918_mb_gtx_rk918_v1.10
EKB311B(CS918) Android 4.4 固件-07.10
Geekbuying T-R42_ B351V2.0_20131203
Geekbuying_TV BOX_RK3188T_Android 4.4_official_AP6210
Q7V 中性 13.2xbmc 12.9 update
rk3188_4.4.2_box_q7_v004_20150121
T-R42 New stock firmware 0928 By Geekbuying
update_EKB311_20141209
wasser-firmware-kr42-new-1.0
K-R42_justXBMC_by_lewy20041_v1.1.1
im confused about the many different Versions of the Box,by the Name i was sure that the cyxtech_rk31_cs918.... roms fits to the Box,but no Chance.
Can somehow explain for which Keywords i have to search Firmware?
Is v7 similiar to Q7
,can i use v7.10 or a higher Version number e.g. #20150121,
by the SoC RK3188-t can i use FW for T-R42
or is only for
"Cs918 v7_0 #20141208"
possible?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
discjockeyr while I was experimenting (unsuccessfully at this time) trying to create a bootable SDHC card - I noticed that exact behaviour with an incomplete boot area on SDHC. I think you managed to overwrite the boot area (first 81920 sectors) in NAND with invalid data. I'm unable to help you but maybe this extra info could point you to recovery.
@ discjockeyr
Use RKAndroid Tool and activate the Checkbox for Loader under Flash and set the Location to your RKLoader(L).bin then hit "Erase IDB"
This is needed when you flashed your Box bevor with a wrong Image.
Download and Use RKloader(L)2.xx.
Originally posted by Berriak-TX View PostCopy of my rom, after installing it, it is necessary to mount the nand flash.
https://mega.co.nz/#!dQhzRIaY!F6HsUQ...xW60OeSZirH56M
MOTHERBOARD: CS918 V7.0 20141208
CPU: Rockchip RK3188T
RAM: Nanya NT5CC512M8GN-CG (512x4=2048)
NAND: SK Hynix H27UCG8T2BTR (8GB)
Audio: Rockchip RK1000-S
Wifi Bluetooth: Realtek RTL8723BU
HH4JB05Y22 GL850G
Rockchip RK616
Ethernet: IC Plus IP101GR
Vendor software version: RK3188_R-BOX_ANDROID4.4.2-SDK
Kernel: 3.0.36+ ubuntu@google-server #307 Wed Jan 21 10:35:35 CST 2015
compilacion: rk31sdk-eng 4.4.2 KOT49H eng.ubuntu.20150104.160843 test-keys
I have tried to introduce this rom in a Cs918 v2_6 20140929 and it seems that it works quite.
CS918 v2_6 20140929 has 1GB, the **** seller was saying that 2GB. Claim to the seller.
RAM: Nanya 1442 NANYA NT5CB256M8GN-CG (256x4=1024)
Part Numbering Guide http://www.nanya.com/
Pardon for my English.
I downloaded the backup
But Ayn no idea what I was doing with the software?
Usw RKAndroid Tool,Connect the Box to PC,hot Reset and Power in.After a while the Tool say "Rockchip Device found". Then activate Loader (if you haved flash a wrong Firmware before) and activate all Parts that in the Firmware you downloaded and give the Path where they locatet,e.g kernel c:\myrom\kernel.img and so on.if its needed to flash Loader you must download the Loader.bin also and give the Path to this File, dont know the exactly name at this time,i think RKLoader(L).2.16.bin. (Im at the camping suite ;-)) then erase idb twice and when this was successfully done hit flash Rom!
Sorry for my Bad english,too much beer! :-)
Q7 cs918 Android TV Box RK3188 2 GB
Image 1 - Before update
Image 2 - After updade
File: update_Q7_20150330_2G_ROOT.zip
link: http://pan.baidu.com/s/1mgyxVzM
Folder: http://pan.baidu.com/share/home?uk=2...ategory/type=0
There are currently 3181 users online. 1 members and 3180 guests.
