[Help] MK808B Plus with RTL8723bs (Wifi not working after finless1.1)
I just received my MK808B Plus but it turned out that it has different wifi chip. After flashing Finless 1.1 now it is not having any wifi connectivity. Could someone please help me flash rtl8723bs driver or compile a Rom that adds support to it or any other solution to resolve this. Thank you in advance!Last edited by fstab; 24 February 2015, 16:08.Tags: None
I am not sure if it isn't clone of some kind, because with original firmware it did not identify as MK808 Plus, but EC-MK808B.
I bought it from here
The mainboard is marked as EC_MK808B 1.0 maybe specially developed for the seller Shenzhen EC Technology Co (www.szetech.com) IDK
I don't have any impressions about the rtl8723bs - I didn't test it at all, I flashed Finless 1.1 as soon as I got the device, because the firmware it came with was awfully sluggish and buggy.
Anyways I will PM Finless about this
[Edit] He has his PM's disabled, so I can't reach him directly
Thank you!
Originally posted by ultimatexbmc View PostYou should PM Finless - just in case he is not aware of this hardware change. I wonder if using this wireless chipset improves the WIFI on these things, as the other versions are a little weak.
Unfortunately I haven't fixed it yet - I use usb to ethernet adapter. But the seller send me yesterday a link to the original rom: http://pan.baidu.com/s/1eQImf2i
Now I am trying somehow to extract rtl8723bs.ko module from the .img file.
If someone could help me with that - I would be really grateful.
Originally posted by lozo View PostHello I have exactly the same problem, the same mainboard EC_MK808B 1.0. did you resolve the problem?
Have you tried to install this rom? Does wifi works? I have problem to download this file it allways fails. Could you please upload firmware to jo dropbox or google drive and send mi the link?
Originally posted by fstab View PostUnfortunately I haven't fixed it yet - I use usb to ethernet adapter. But the seller send me yesterday a link to the original rom: http://pan.baidu.com/s/1eQImf2i
same build
I have received the same build yesterday.
i bought from the same seller as yours.
this is what i tested for so far:
- wifi connection is stable.
- usb lan not working (i have an old mk808b where it works without problem, used same adapter)
- play store, apps very restricted and many many apps not compatible.
- does not come pre-rooted.
- google sees the tv box as a phone. TV box is in landscape. But even in landscape. App like spotify shows only portrait mode. also Big Fail.
hopefully someone can build a rooted, spoofed tablet play-store, wifi/usblan-working firmware for us.
I finally resolve the problem by installing the rom fstap provided http://pan.baidu.com/s/1eQImf2i. I used USB burn tool to install and not throuht sd card as written in instructions . I think that this is not the rom that was orginal installed on my device because it now says that i have model mk808b without plus. But it now works. I tested the remote controler program RemoteIME.apk and it works. XBMC, facebook,gmail,dropbox,youtube,chrome,drive..works but could't intall them throuht googleplay but manually.
I have uploaded the original ROM to Dropbox - here
I didn't flash the original rom for the reasons that miljano mentioned - it is really bad (most apps on Playstore won't install; no root; and slow in general)
Finless 1.1 works far better. Currently I use it with USB2Ethernet adapter (I have tried 3 types and it only works correctly with 1 of them - one from Asus that I got with my Zenbook - here; Other 2 were generic chinese usb adapters: like this and this).
Unfortunately I don't have enough knowledge to extract only the wifi driver from the original rom and load it in finless 1.1.
If someone is experienced enough in this stuff, his/her help will be highly appreciated.
ThanksAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
Originally posted by killeriq View Postjust curios, which USB LAN adapter do u use?
The seller just send me the rtl8723bs.ko file 8723bs.zip
Can someone help me permanently load it into finless rom?
There are currently 3200 users online. 1 members and 3199 guests.
