Help me ID the rom installed on my m8
    Hi, i have two am logic square m8 boxes.
    they were both running on july 2014 firmware. Ive since had one of the boxes replaced by the seller, and the new box, came with newer firmware. Its miles faster, less judder on the launcher.
    when an app starts up, a rocket launcher animation appears as well, freeing up resources.
    the firmare is dated KOT49H.20141130 test-keys
    it came pre bundled with 13.2 gotham xbmc, with a load of addons i dont need, so now removed.
    i want to restore my first m8 box with this new firmware, but seller says they have no update files for me to put on sd card.
    so i was wondering if anyone might know if they are using a common image file, that i can grab from here?
    Ive attched some pictures.
    Upside down images at that, cant seem to work out how to rotate them.
    Some other things to note about this firmware is that, the mouse pointer is huge.
    just cant seem to find anthing when searching for the firmware date.
      It seem like from ENY Firmware
        m8 rom
        try m8 gev2 from here. http://mbox.co.za/forum/viewtopic.php?f=64&t=337
          you box is ACEMAX
          Bugs are Sons of Glitches!
          JustMe
