beelink r89 rk3288
    beelink r89 rk3288
    Hi
    i bought beelink r89 rk3288 but i have problem with wireless keyboard.
    whe i type one letter it start typing the same letter continuously
    i have tried many firmware and many keyboard but nothing helps.
    Is it hardware issue or?
    please help me
    Try to connect keyboard to OTG port, that should fix the problem.
      beelink r89 rk3288 wireless keyboard.
      problem fixed thanks
      Is it this problem with all beelink r89 rk3288 boixes and why?
        At all devices (netxeon pcb) with SOME wireless keyboard because the OTG is directly conneted to the rk3288 while all other USB-Ports working via an internal USB-HUB-chipset at the pcb (I think also at devices using e.g. the t-chip pcb becuase they e.g. seems to use the same USB-HUB-chipset)
        RK3288 Devices
        - Overview BOX (LINK !)
          I had same issue with my previous box (K-R42). Keyboard was useless at beginning connected to normal usb port on stock firmware. Then i have installed wasser-s one, and all worked excellent. With that box it was software issue. With this one i dont know. I have experienced problems with all rom-s that i have tried. Keyboard works ok only via otg port.
