i recently bought a M8 Anrdoid Player with 2gb memory, but there is problem with the movie play, while the movie play smoothly it is skipping some frames, i tried 4K Player and mx Player and xbmc, and still same things happens. I have also tried many different settings. 1080p/60hz,1080p/50hz,1080p/24hz. I tried watching movie from hard disk driver and USB stick, and all the same. My old raspberry PI Works perfectly. My tv is a Panasnc Viera ET60 (600hz) and the vision is too intense because of big scan. Can anyone (with the same problem) help me solve this?
M8 Andoird movie Skip frames!!
hi
i recently bought a M8 Anrdoid Player with 2gb memory, but there is problem with the movie play, while the movie play smoothly it is skipping some frames, i tried 4K Player and mx Player and xbmc, and still same things happens. I have also tried many different settings. 1080p/60hz,1080p/50hz,1080p/24hz. I tried watching movie from hard disk driver and USB stick, and all the same. My old raspberry PI Works perfectly. My tv is a Panasnc Viera ET60 (600hz) and the vision is too intense because of big scan. Can anyone (with the same problem) help me solve this? -
Originally posted by grant2258 View PostMake sure you do a factory reset after it boots. This apply to any rom you update
I upgraded with M8N ROM - S82 NCv5 with Kodi (Custom) and now my M8 work perfect and 1080/60hz and 1080/24hzno way to have the interface the android 1080p/60hz and movies in xbmc 1080p/24Hz?? how to change automatic? Thank you very much.
Not tried dual setup like that try system-> settings-> video-> playback and set display refresh to match video as always. This works fine on my raspberry pi 2 not tested it on my m8 box I know it doesn't do jack on my rk3288 box. Only thing I can think of. Make sure you pause for a few seconds with the setting underneath as well so you know if the refresh is changing
Originally posted by grant2258 View PostNot tried dual setup like that try system-> settings-> video-> playback and set display refresh to match video as always. This works fine on my raspberry pi 2 not tested it on my m8 box I know it doesn't do jack on my rk3288 box. Only thing I can think of. Make sure you pause for a few seconds with the setting underneath as well so you know if the refresh is changing
In fact , I'd like to know , what is Drop Frame and Skip Frame?
There are currently 2399 users online. 0 members and 2399 guests.
