XT-Q7V-V10 Has anyone made this device stable??????
Has anyone made this device stable i flashed this firmware update_7_30.zip and it worked some time with occasionally device reboot but now it started to reboot more frequently and every version of XBMC that i thought of it crashes to desktop very offten. Device has became pretty much useless. Is anyone having similiar problems and know how to solve this .
ThanksTags: None
I am having the same board and currently searching for the best firmware, because with stock 20140808 there is only mono audio from AV and only 720p as choice,
I am thinking to 20141209, have you tried it?
Originally posted by offlinefeaks View PostHas anyone made this device stable i flashed this firmware update_7_30.zip and it worked some time with occasionally device reboot but now it started to reboot more frequently and every version of XBMC that i thought of it crashes to desktop very offten. Device has became pretty much useless. Is anyone having similiar problems and know how to solve this .
Yes i tried , its a little bit better but unstable again reboots frequently crashing xbmc and alot other stuff just unstable. Now im using jellybean rom and it is alot stable than any other kitkat i tried. If anyone knows a good kitkat rom that is stable with this box please post and i dont care about speed of rom anymore just stability.
Give a try to
Download latest Android 4.4 KitKat for EKB311 / MK888 / K-R42 / Q7 / CS918 TV Boxes from here or here . Down...
I have no reboots of problems with 20141209 so far or with my stock either. (maybe your reboots problem has to do with something else)
there are 2 more older ROMS in this site but I think the above link is for the latest
Originally posted by offlinefeaks View PostYes i tried , its a little bit better but unstable again reboots frequently crashing xbmc and alot other stuff just unstable. Now im using jellybean rom and it is alot stable than any other kitkat i tried. If anyone knows a good kitkat rom that is stable with this box please post and i dont care about speed of rom anymore just stability.
Originally posted by offlinefeaks View PostOK thanks i will try it as soon as possible, what about XBMC did you test that? Also i think real test for these reboots to occur is running some games. On every rom i tried when i run game sometimes it can play for hour but usually less then device reboots or just shut down.
on my eyes and based on computer experience these problems you are referring sounds like overheating or bad memory, I would try with open box or by adding a small fan near a hole temporary to check.
I 'll try some gaming later tonight and let you know.
Originally posted by a123xxsp View PostXBMC 13 (embedded) runs fine to my box, I installed 14 and it randomly crashes
Originally posted by offlinefeaks View PostMy box doesnt overheat at all doesnt have temp problemms its very cool. As for the hardware i dont think its hardware fault all these problemms we have with roms all software based, simply roms aren stable.
the only problem I have now (also had with all previous ROMs) is that from AV out I got mono sound no stereo, optical out is OK.
please let me know if you test the other roms
the second one is for the v7 of the board (I suppose),
so I am back to 20141209 ... better than my stock but still no good enough
Originally posted by a123xxsp View PostNever mind checking the ROMs above, I tried the rooted one, many things go wrong after a while,
I'm using this rom a couple of month. My tvbox connected to Internet via Ethernet cos' when its connected to WiFi some lags whith wireless mouse occured. Also sometimes in 1080p mode video signal disappears on 1-2 seconds. I think its hardware problem..
You can also try this stock ROM
Regards & sorry 4 my bad english )
Originally posted by vitos747 View PostI'm using this rom a couple of month. My tvbox connected to Internet via Ethernet cos' when its connected to WiFi some lags whith wireless mouse occured. Also sometimes in 1080p mode video signal disappears on 1-2 seconds. I think its hardware problem..
There are currently 1822 users online. 0 members and 1822 guests.
