How do you all navigate in XBMC? what can i doing for this ?
XBMC not responding to mouse clicks
I just bought an MK808 Finless ROM 1.5A installed and loaded XBMC I am using a computer mouse to navigate this device. I can click on the XBMC icon and launch the app but then cannot click within the app. Using a USB keyboard, the arrow keys (up, down, left and right) work but "enter" does not. Cannot select any tab in XBMC.
How do you all navigate in XBMC? what can i doing for this ?Tags: None
xbmc settings for mouse
Within the settings menu in XBMC there is an option to enable or disable mouse and/or touch support. I think it is disabled by default because of the high percentage of people who use a remote control or a remote control app to control XBMC. With it enabled many remote controls and even keyboard arrows move the pointer like the mouse does rather than like a remote control that you use to navigate menus by jumping from item to item. Check in your XBMC settings and enable it if it is not already enabled.
There are currently 2503 users online. 1 members and 2502 guests.
