Bios chip
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by cappybob View PostDumb boy question here. The Intel chip uses an eeprom? I can understand this, but does it lock the system to a "only what "I" allow OSes". I can see good with a possible standardizations, and the bad with chip company's owning your electronics forever.
--cappybob
Z64A BIOS
I have extracted the bios using the efi shell.
I Have used the following efi executable: AfuEfix64.zip copied on an UEFI Windows 10 Boot USB.
And was wondering if someone could provide me with a Z64W (Windows version) BIOS
The Z64A (Android version) BIOS : current.zip
Step by step guide:
- Boot into the BIOS (Press Del)
- Go to Save & Exit > Boot Override > UEFI: Build-in EFI Shell
- You are now in the EFi Shell
- At the prompt Shell> type: fs1:
- Navigate to the folder you extracted the AfuEfix64.efi executable.
- Type: AfuEfix64.efi current.bin /O this will dump the bios in current.bin.
And hopefully if users restore the bios of the Z64W on a Z64A it will allow them to install Windows 8.1 or Windows 10.
I do not know if the Z64W is using the 64-bit version of the efi shell if not you could get an error message telling you that the AfuEfix64 is not supported.
if that is the case please tell mee and I will provide a 32-bit version (AfuEfix32.efi)
Thanks in Advanced
Looks like you've made a backup of only a part of the bios.
There has to be Winbond W25_32 chip on the board near the CPU, this is 32M-bit EEPROM. Full dump should be 4 194 304 bytes.
Try to make a backup using bootable flash and Intel FPT tool:
fpt -d bios.rom -BIOS
FPT can be downloaded here:
Originally posted by Cathode View PostLooks like you've made a backup of only a part of the bios.
By typing W25_32 i meant any letter instead of "_" (Q, D, X). It doesn't matter. Total capacity is the same.
Damn, Z3735F platform doesn't include Intel Management Engine, that is needed to run FPT.
Looks like the only way is to read the eeprom content using any SPI reader.
No luck so far, flashrom sees the bios chip but i must have something off as its throwing out the error 'Found generic flash chip "unknown SPI Chip (RDID)" This flash part has status NOT WORKING for operations: PROBE READ ERASE WRITE
The bios chip for the android version im trying to dump is actually a Winbond 25Q64fwsig and I cannot find a pinout on it but i found on the newer variant the fvsig and it reads as below
CS <=======> CS
GND <=======> GND
CLK <=======> CLK
3V3 <=======> VCC
MOSI <=======> DI
MISO <=======> DO
if anyone would like to chime in and save me the time of fidangling with all of this im gonna have a beer
Update: theres something thats just not right here, I know i got everything connected correctly, ive updated the fw on my bp and tried in both windows and linux and flashrom just cant recognize this thingLast edited by alwaysbless; 28 February 2015, 06:00.
Originally posted by Cathode View PostIn my previous message i've inserted link in "SPI reader" where you can buy cheap as hell programmer and read everything you need without any problems.
There are currently 1954 users online. 1 members and 1953 guests.
