Custom Recoveries Freakbox
    On this thread you will find all custom recoveries available for the FreakBox.
    For Stock image
    TWRP 2.8.5.0 - www.freak-tab.de/abdul_pt/FreakBox/TWRP_2.8.5.0_SDcard.img
    For CM11
    TWRP 2.8.5.0 - www.freak-tab.de/abdul_pt/FreakBox/TWRP_2.8.5.0_SDcard_Data.img
    CWM 6.0.5.1 - www.freak-tab.de/abdul_pt/FreakBox/CWM_SDcard_Data.img
    How to install
    1) I have made a small batch script, that flashes TWRP without the need to enter in bootloader mode. The only requirements are that you have ADB setup and have a insecure boot.img (ADB Shell run's as root). If are running a FreakTab rom, them you have it. If you aren't running one, well you should.
    Download this script, and unzip it. Rename whatever recovery you downloaded to recovery.img and place it inside the recovery folder. Connect device, with USB Debug checked and double click installer.bat. Profit.
    2) You can use one of the Rockchip's flashing tool's. On the flashtool select the recovery.img of your choice, confirm offset location, if you are uncertain use the same parameter file that you used to flash the Rom. Connect the device in bootloader mode to the PC, DON'T ERASE IDB, and press Run. Enjoy
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    Be nice to have a how to for us n00bs
    FLHT = Harley
    HEMI = 2010 Dodge Challenger SRT
    Cause I've been asked.
      You are right.
      I will edit the OP
        Originally posted by abdul_pt View Post
        You are right.
        I will edit the OP
        You're a good man! What version of flashtool? 1.7?
        FLHT = Harley
          The one used to flash single image files. The RK Android Tool or the Android Release tool.
          On a quick link you can check this folder
            If you have a Freakbox, I presume you have a Freaktab ROM...
            Freakbox V1 F/W 1.0.6
            Asus Zenfone 2 ZE551ML Stock (rooted)
            Samsung Galaxy Tab 3 7.0 Nolekat 2.2 custom ROM
            Asus TF300T Cyanogenmod 11 Snapshot M12
            Archos 35 Home Connect Stock 2.3.4
              You are welcome.
