New tvheadend for rk3188 and rk3288
    compiled newest tvheadend with dvbcsa on lubuntu.
    No need to crosscompile, because of the same kernel.
    Thanks a lot to ChristianTroy from wetek play forum.
    He did this for wetek play and so it was easy to reproduce.
    Copy libs to system/lib and tvheadend to system/bin.
    Change drivers in 02tvh to yours and copy to etc/init.d.
    4shared is a perfect place to store your pictures, documents, videos and files, so you can share them with friends, family, and the world. Claim your free 15GB now!
    Tested with T-R42 and CX-998 on original rooted Android-firmware.
    Regard
    Daniel
    Tvhheadend with transcoding enabled
    This is Tvheadend with transcoding enabled.
    Compiled with static ffmpeg and avahi enabled.
    Tested on CX-998 and Kodi 15.1, latest nightly.
    After 2 hours no continuity counter error and no crash with newcamd.
    I dont know how to see, if transcoding is working.
    Would be nice if someone test this version and give a feedback.
    Daniel
      Thanks for posting this.
      Do you have any other way to download these?
      4shared sucks and just doesn't work for me.
        Here you are.
        RK3188:
        RK3288:
        Rk3288 with transcoding:
        http://www11.zippyshare.com/v/skuTK7PE/file.html
          Sorry, tvheadend bin file was the wrong one in the transcoding zip.
          Replace it with this one:
          Daniel
            Thanks Daniel.
            I'll try it out tomorrow and let you know how it works out.
              dados pls compile tvheadend with hdhomerun. because need clarkss12. "Also, I have a HDHomeRun ATSC tuner. They do have Linux drivers."
                Try this bin with transcoding libs.
                configured with --enable-hdhomerunn_static.
                Dont know if you need something else for hdhomerun.
                Daniel
                  I no need hdmorun. freaktab user clarkss12 want tome for compile. ndk dont buid. can you have build script armf compiler
                    Thanks Taki and Dados, that would be great......
                      you use armf compiler that possible full vdr port on android.
                        Thanks Daniel.
                        Unfortunately it's not working just yet.
                        I can't get TVHeadend to start and can't see it in Chrome (through port 9981)
                        Are there any files missing?
                          Dados missing rename so library. Thus start manual with terminal that you look whic library so needed. After rename library. At the and of reboot
                          I compiled w_scan for android perfectly work and scan dvbs.
                            Ah ok. Thanks Taki, I'll try this.
                            I was wondering if the .hts files might have been missing.
                              Tvheadend is full version with version number and help files.
                              I think i have forgotten to rename libdvbcsa.so.1.0.1.
                              Rename it to libdvbcsa.so.1 and it will work.
