Has anyone run into google playstore not working on the M8/M8N box? The time and date on the box is correct and I even tried updating playstore to the latest version but, there's still a connection error message that comes up when trying to go into playstore.
Google playstore not working
Hi all,
Has anyone run into google playstore not working on the M8/M8N box? The time and date on the box is correct and I even tried updating playstore to the latest version but, there's still a connection error message that comes up when trying to go into playstore.Tags: None
Also I no you have said you have tried updating the play store but have you tried uninstalling the updates to the play store, I had a problem with the play store the other day so I uninstalled the updates & it worked fine after.Please consider making a Donation to freakTab
thanks for the suggestions guys. I did try rebooting, clearing cache, when you say signing out do you mean remove the account from settings and re-adding? I didn't try removing updates, will give that a go when I get a chance and report back.
update: After trying all that was suggested I thought maybe the google play services being out of date was the problem so, I updated that and still nothing. The one thing I noticed when I went to the system update settings the last checked date year for update was 1960 so, it looks like somewhere in the system the date is wrong even though I checked and it shows the correct date.Last edited by thekider; 02 March 2015, 03:19.
Originally posted by thekider View Postthanks for the suggestions guys. I did try rebooting, clearing cache, when you say signing out do you mean remove the account from settings and re-adding? I didn't try removing updates, will give that a go when I get a chance and report back.
update: After trying all that was suggested I thought maybe the google play services being out of date was the problem so, I updated that and still nothing. The one thing I noticed when I went to the system update settings the last checked date year for update was 1960 so, it looks like somewhere in the system the date is wrong even though I checked and it shows the correct date.Bugs are Sons of Glitches!
JustMe
I updated The google playstore and google play services manually so they were the latest available. can't remember the rom version but, it was a stock rom one of the newer roms from January (box is no longer with me).
edit: checked and the firmware is stock 20150113Last edited by thekider; 13 March 2015, 17:43.
There are currently 3751 users online. 0 members and 3751 guests.
