hel please cs918
hel please cs918
hi guys been weeks trying to sort this, ive got the rkbatch tool trying to flash this box, it wont connect to my pc, been into device manger but nothing, ive have no replies in this thread http://www.freaktab.com/showthread.p...-please-RK3188 , please some one help me out thanksTags: None
ok try first erasing everything before you try to install a new rom.
for this crucial step I use a rk3188 rom tool made by finless bob which gives you the choice to erase. That's all I can tell you there.
No one more thing I can tell you that is to use a windows 8 computer not 8.1, 8.1 may not recognize the drivers. Sometimes you have to manually install the drivers. And for some androids you plug in first and some you plug in when you plug in the usb. I have seen many conflicting instructions regarding the plug order
biggest question we have right now is does your computer recognize the device at this time? That's step 1 you'll see a green light in the android tool or device recognized. get that accomplished and the rest is easy. But erase it all once you get it recognized, that's the right way to do it. THEN install your rom of choiceLast edited by Electroman; 01 March 2015, 16:35.
Originally posted by Electroman View Postok try first erasing everything before you try to install a new rom.
look for a rom specifically for your box made by finless, make believe you are installing his rom as per his instructions, ok now once inside his rom instalkation tool look for erase or erase nand flash and hit it, now you have erased everything on your drive, now proceed with installing any rom you like, fixed, done.
Look in this forum for a rom made by finless for your cs918 or kr42 same thing and proceed. Download it to your windows 8 comp then open it with win zip and follow the read me instructions . Finless rom tool has the ability to erase.
Do not deviate from this, I don't know what you have at this point.
Your goal is to erase your nand flash that's the hard drive within your android . You have to erase it before you start putting a new rom on it.
If you get stuck do some googling Google erase nand flash on android and .
ok here is the app you need to erase your drive, this is one that works:
ROM_Flash_Tool_21.exe and it is actually found in the mk908 rom by mr finless
This should get you erased, then go ahead and try to install new after that. You should be able to repeat the procedure if you are still bricked. You have to go to the second tab in the tool and on the mid right there is a button for erase nand
If you still have trouble let us know.Last edited by Electroman; 03 March 2015, 03:24.
There are currently 1440 users online. 1 members and 1439 guests.
