Buttons on XBMC
    Buttons on XBMC
    Hi all
    New to this upgrading Firmware and Flashing, I have MK908 Stick and on it is Finless_1.8 and I installed XBMC Kodi following instructions and all works ok. Problem I have is the buttons on xbmc when loaded does not show a Sports button,is there any way I can add one and set up short cuts to add my sport channels etc., I cannot seem to find anything in settings other than the ones built in.
    Thanks for looking in advance
    Michael
    Originally posted by Michael_k View Post
    Hi all
    Michael
    If you are using the Confluence skin that is the "Stock" out of the box skin, then you might want to try a skin by a guy named "mudislander". There are 3 he is working on for Kodi Helix that are VERY customizable skins and adding favorite short cuts are no problem.
    See here:
    For Hybrid a work in progress and not fully functional but can be used
    For CCM for Helix:
    For Convergence Thread indicates it is for Gotham but if you install the mudislander hybrid repo, you can get all 3 and keep them updated automatically:
    Hybrid Repo - this link will start the download of the repo .zip file. Install from zip file in Helix addon browser. You can also get it in one of the skin threads.
    This really is a question about Kodi and not your stick and I would suggest you JOIN the Kodi TV forums as there you can get all the help you need about Kodi!
    FLHT = Harley
    HEMI = 2010 Dodge Challenger SRT
    Cause I've been asked.
      Hi all
      Michael
      We have an idea or 2
      Team UX
      http://www.ultimatexbmc.com/
      http://www.freaktab.com/showthread.p...-ULTIMATE-XBMC
        Hi
        Thank you for your quick response, it was much appreciated.
        Michael
