Mxq quad wifi dropping
Hi I am new to these forums and I am having a problem with my mxq box it disconnects wifi every 15 minutes. I have updated firmware and it hasn't helped. I have sent box back and got a replacement one just in case it was a faulty box but the new box is doing the same thing. I would like to know if anyone else has or had this problem and how did they solve it. -
Originally posted by trev299 View PostHi I am new to these forums and I am having a problem with my mxq box it disconnects wifi every 15 minutes. I have updated firmware and it hasn't helped. I have sent box back and got a replacement one just in case it was a faulty box but the new box is doing the same thing. I would like to know if anyone else has or had this problem and how did they solve it.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostI would look at your router. I found belkins to be terrible. Whatever radio they are using is not good. All my other devices are fine just my androids work funny.
Thank you for the reply, I am using cable modem (virginmedia super hub 2) have changed the channels but it still disconnects from wifi at 15 minutes then I have to go back into settings on the box and reconnect to the wifi. It also disconnects when using Ethernet cable I think it might be something within the box settings but can't figure out what it might be.
Originally posted by assmunche View PostTry a factory reset. Or update the firmware. The latest is 109. Also set your router to b.Last edited by trev299; 02 March 2015, 23:35.
There are currently 2760 users online. 0 members and 2760 guests.
